Hi, Experts u had done lot of projects on navision . I am expecting an answer from u regarding AUTOMATIC COSTING METHOD In inventory setup.What is your suggestion on these. What is the best method Do I need to place a check for Always or Do I need to run the A.I.C. E & Post Inventory cost to G/L at non working hours.Please share u r ideas regarding this issue.Which method U followed.Thanks and regards
My typical settings (rarely changes)
Automatic Cost Posting = YES
Expected Cost Posting = YES (sometimes, but rarely, no)
Automatic Cost Adjustment = NO (run nightly Adjust Cost)
Experts share some more ideas os this issues…
I would agree with babrown, jist the odd one that maybe different, depends upon the customer
From above explanations what I could understand
If I want to run the Batch job AICE, Post cost to G/L periodically at non working hours then these must be
Automatic cost posting = No
Expected cost posting = No
Automatic cost Afjustment = NO
Is it correct ? I
If I don’t want to run the Batch job AICE, Post cost to G/L periodically at non working hours then these must be
Automatic cost posting = Yes
Expected cost posting = YES
Automatic cost Afjustment = YES
Is it correct ?
Let me know what is proper method ?
What is the period to run the AICE, Post cost to G/L Batch jobs that means daily , or weekly, 15 days….
Throw some light to comeout from dark.
Experts throw some light on this…
Nope you have it wrong
The automatic cost posting works differently to how you think, as does the expected cost posting - these really are not related to working hours and running the job. You need to know whether to post costs at the time of systme processing, and then if you want the interim costs posted as well.
How often you run this depends on the business and the costing method and the processing, so I have seen all of the settings you describe used. I would answer that you need to run this as frequently as you need to run it to see adjusted costs.
Thanks Steven sir,
That means Even I have this steps
I need to run the Batch job AICE, Post cost to G/L periodically Is it correct ?Thanks and regards
It depends upon the period in the “Automatic Cost Adjustment” field, but I would still answer yes, run the routine to ensure you have everything.
Thanks Steven,
please let me know the which is the best period in " Automatic cost adjustment " Field?
What is the best period to run the Batch job AICE, Post Inventory cost to G/L ?
Please throw the answers .
Thanks and regards
There simply is no “best” you have to apply it to the needs of the business. Set teh automatic cost adjustment appropriate to the business and run teh batch jobs as often as the business needs.
