Hi, Does anyone have problems with Automatic Cost Adjustment Field on SP1? I tested using Automatic Cost Adjustment Field = Day and found out the COGS was doubled. However, if I change that filed to be “always” it worked fine. Is anyone using that filed? Thanks,
I just checked with the Release Notes of SP2. This does not seem to be a known issue and will not be solved with SP2. So you should leave it with “Always” I guess [:D]
we had it set to ‘Always’ for 2 months, but we switched it of, because it was causing too much delays. In some cases, finishing a production order took between 3 to 5 minutes.
