How can i have autogenerated reports sent to my personal email address? I know that when starting a report you push CTRL + SHIFT + S to set up when you want the report to generate but I want the reports to send to my work email as well.
Hi Oscarcon?
Which version of Dynamics NAV are you using? If using older versions, then it requires a lot of changes, if in the newer (2016+), then not so much. Otherwise there are a few add-ons which can do this.
We use Microsoft NAV 2015. How significant are the changes? Is there a way to have auto generated reports send to a distribution email?
