Hello; I have been experimenting with the auto-replace property in dataports. When set to “Yes”, then “No” again, my dataport still auto-replaces. Is there some other property that may be affecting this behaviour? Brian.
You have 3 properties for setting the behaviour of the dataport: AutoSave, AutoUpdate and AutoReplace. Try and hit the DEL key and all three of them to make sure you have them at the default values. Hint: look at the online help (f1) for further information on the properties. Soren Nielsen, moderator Integration/Developer NOLUG
