in the Physical Inventory Journal report there is a requirement for a dimension/audit code. We would like it to always be ‘00’. Is there a way, w/out a program/code modificaton, to make this happen? Is there a field(s) in a table(s) I can change or a global setting or??
The users were throwing fits because leaving out the dimension code resulted in extra lines in the report output. They could not seem to make the search/replace-all work until we pointed out that they needed to check the “Replace Entire Field” box.
