Auto Login in NF - is it possible?
Greetings to all NOLUG members! I have a little question about automating some processes: Does anybody know the way to auto login into Navision Financials? When Main Form runs and I get the required USERID? Thank you.
Do you mean, a way to bypass the Navision Financials logon screen?!? If you do, there is an option via the File, Database, Options menu called UNIFIEDLOGONALLOWED. Set this to YES and make sure you click on the OK button. It will work next time you close and reopen the program. NB. If it doesn’t work, check the option again to make sure it didn’t reset it to NO.
PS: from version 2.50 on this is called “Authentication Method” and is selected when you open the database, or connect to the server. You want Authentication = Windows Authentication. Beware of user ids over 10 characters long in some versions. _________________________ David Singleton Navision Consultant since 1991 dmks22@home.com___________
