Auto-create field on the Registration form
There are some articles/posts that talk about a Auto-create field (in fact is a check-box) which appears on the Registration form which was opened from Purchase Order DetailsInventory->Registration (lower pane). But in my screen this field does not appear. How can I make it appears?
Thanks.
Hello Adrian,
Can you please check this field Auto-create in the user Setup of the Registration form (Purchase Order DetailsInventory->Registration) whether it is visible there or not? Right click on the form and select Setup.
Thaks for your reply and the answer is that It is not visible.
Might be obvious but I presume you have now ticked it as visible and you can see it?
Hello Adrian,
This is the reason that the field Auto-create is not visible in the Registration form (Purchase Order Details->Inventory->Registration). Right click on the form and select Setup → Select the Auto-create field and make it visible → Save your settings.
When you’ open the form again you’ll find this field visible in the Registration form (Purchase Order Details->Inventory->Registration).
For me that button is not visible at all. This mean I can make it visible. Somehow I found that solution to my problem was in AOT (Form->InventTransRegistration->Design) and here you can make it visible for users, because it seems that here you can hide it for good.
Anyway, thank for your interest on my problem.
