As per my knowledge, we do not have automated bank reconciliation in AX2009 which is now available in AX2012.
In AX2012
It matches the transactions based on the rules that are defined. (you can set like compare the check number and voucher number) based on that the matched entries will be shown in matched trans grid in the form. It allows to unmatch and match with the needed ones.
the transactions which cant be matched with defined rules will be shown in a seperate grid
Adam, by chance do you have any sample xml file of Bank statement that can be imported into AX. I’m confused to search it in the partner source. Could you help me with that. I’m done with all the setups and just need to import it and check whether it works. I will be very thankful.
There is a bank statement format setup and the reconciliation matching rules define what the bank reconciliation will use in the matching machine from the format defined.
