Attain Sizing Guide & Questions
Hi, We’re running Navision Attain using the Navision database engine (not MS SQL Server). We’ve gotting approval to upgrade the server, but I haven’t been able to find much information regarding proper sizing of this server. Can anyone provide a link where I can find more information? More info on the existing system: 4 GB database ~60 concurrent users (expecting another 20-30 this year) Thanks, Ken McCord MIS Manager A.C. Coin and Slot
Your sizing depends on the amouts of transactions. You have a small database compared to the number of users. Can You tell us a little about numbers of invoices, items, orders and so on? Without knowing anything about the above I would say: - Single CPU - 1GB RAM (~750 for cache) - 10 disks in RAID-1 - pair 0: OS and exe’s - pair 1: db01.fdb - pair 2: db02.fdb - pair 3: db03.fdb - pair 4: db03.fdb Maybe more disks (and database parts) if You have a lot of transactions, but then again, You didn’t have such a big database.
Here’s some data on a select group of tables: Table No.Table Name No. of Records Record Size Size (KB) 21 Cust. Ledger Entry 55146 1397 75216 25 Vendor Ledger Entry 136533 881 117512 27 Item 22688 1007 22312 32 Item Ledger Entry 287667 1415 397568 36 Sales Header 4197 1105 4528 37 Sales Line 29392 1397 40112 38 Purchase Header 21440 778 16288 39 Purchase Line 155315 967 146728 110 Sales Shipment Header 22038 845 18184 111 Sales Shipment Line 152343 413 61376 112 Sales Invoice Header 38501 750 28208 113 Sales Invoice Line 164818 635 102216 114 Sales Cr.Memo Header 2657 706 1832 115 Sales Cr.Memo Line 15767 393 6056 120 Purch. Rcpt. Header 33235 641 20816 121 Purch. Rcpt. Line 353274 408 140848 122 Purch. Inv. Header 65370 724 46240 123 Purch. Inv. Line 177531 549 95120 We have two .fdb’s on the server, live and test. Test environment will most likely be kept on the old server. We don’t expect to move off the proprietary database engine for several years - does the Navision database utilize multiple processors? I noticed you spec’d only 1 cpu. Thanks again, Ken
No. It’s no use buying more than 1 CPU. How long time have You been running the system (just so I know how long i took You to create the data above)?
We’ve been on Navision since July 2000, but most growth has occurred in the last two years.
