Attain; max. size of blob
Hello out there, does anybody know if the size of a blob, especially for images, is limited in Attain? I remember, there was a limitation of 32 KB when using BMP ( e. g. company logo ) in NF 2.xx. Recently i tried out to import an image with more than 11 MB in Attain 3.60, there was no problem :wink: Regards, Tobias Weber
The maximum size of a BLOB is normally determined by your system’s disk storage capacity. However, the maximum size in C/SIDE is 2GB. Picture limitations only occur if you use the pixture box on a form or report inwhich you show a external picture.
Thank you for your response. Regards, Tobias Weber
You’re welcome.
