For Your Information: There is a problem with the debugger in Attain in that when you do a Zoom within a trace, the debugger traces its own work through the resolving of the Dimension references as well as the Multi-Language references. The result is to make the Zoom function very painful to attempt to use. This has been reported to Product Management in the US. In the meantime, the way I have found to avoid the debugger tracing itself (other than not using the record Zoom feature) is to set all breakpoints manually and turn off the automatic trigger breakpoints. Dave Studebaker das@libertyforever
Yep, One more. You can’t look in globals (or locals) if debugger is without “Breakpoint on Triggers”, and Attain stopped with error. Globals (Locals) windows not opening:((( Attain 3.01a. RGDS Gedas
