Hi all, Im trying an installation of attain 3.10.A on a server2003 box, the installation gets going, and just after the MDAC2.60 part of the installation, you see a roll-back screen, and then a screen saying: “The wizard was interrupted before the installation of Navision Attain 3.10.A was complete. You system has not been modified. To complete installation at another time, you must run setup again” What could be the problem ? Server component running fine The client not… Thanks DANIEL
You can’t use the Windows installer on WTS/Citrix. It’s only the latest hotfix of 3.70 that works with Windows installer in that environment. You’ll need a special script. You can search the forum for it or ask MBS for it.
This should be pretty much what you need and what Lars is refering to: http://www.mbsonline.org/forum/topic.asp?TOPIC_ID=7888 http://www.mbsonline.org/forum/topic.asp?TOPIC_ID=7779
