I have installed the client on a WIN 2000 Terminal server in app. server mode. It works fine, but every time a user clics OK in the logon dialog box, it starts an install procedure 20 - 25 seconds before the program is ready. The Logon box appears instantly when starting the client. Is that normal? Regards Karl
One possibility is copy the client directory onto the ts instead of installing. then the MS-Installer is not aware of the client. the other solution is installing the client with a special installation routine you should ask your nsc or ntr. attention client version 3.10 is not running properly at all on TS ! this is written in the change documentation 3.10A
