hi, Does someone have information about the TAPI Interface in Axapta 2.5 SP 4??? Any info would be interesting! thnx ala
Hi, I am not too sure what info you are looking for. If you want to know whether TAPI is being used with CRM, I know at least couple of installations where Axapta CRM/TAPI integration works just fine. If you want to know how to set up TAPI with CRM, search for this document in Technet - ‘Setting up the TAPI interface for Axapta CRM’. HTH, Harish Mohanbabu
Hi Ala, look into User’s Guide for CRM on the Axapta installation CD. The last chapter is about TAPI.
