Atals For Ax
hi anyone knw how to work in Atlas??? pls help me… thanx…
hi arun you can get any idea about this after reviewing this article
http://ax-global.com/atlas-xl.html
which one i want to install first server or client?
i installed both client and server…
but i cant actiavte the atlas… coz i coulnt find the activate tab :frowning:
pls anyone help me
do you enable the add-ins? you need to enable it before run it.
hi chan wai tuck,
i didnt enable it…
but, i couldnt find the option… where it is???
If in AX, the atlas tab will appear after you install it.
For excel, you need to go to option>add-ins to enable the Atlas.(maybe difference depend to excel version)
sorry, i didnt complete the installation,
while log in its shows error,
contact ur admin,
windows service running correctly
your settings are correct
shows this error
Can you post your error here so that we can help??
Thanks.
-Umang
hi all
i dont have concurrent license key…
is it possible to install with out concurent key???
an i tried to install its shows error…
like,your liscense key server is started …but i checked its started only…
pls anyone help me
Try to check the .net framework.
Last time I also facing difficulty when install Atlas, but that only happen to the client terminal.
