Assignn resources form in Project management ax 2012
Can anyone tell me how to access Assign resources form from the projects in project management and accounting. In TechNet they mentioned Click Project management and accounting > Common > Projects > All projects. Select or open a project. On the Action Pane, on the Plan tab, in the Activities group, click Assign resources. But I am unable to find the Assign resources button in projects form.
Please assist.
Hi Shweta,
If you are working on AX2012 R2 CU7 release, then the assign resource button is moved from the plan tab. And it is available in the AX2012 R2 RTM release.
Balakumar
You can use this link for the new features available in CU7 and resource scheduling white paper is available.
http://technet.microsoft.com/EN-US/library/7f974cb1-fe38-4a96-a931-568cc0676ce3.aspx
Balakumar
Hi Balakumar,
Thanks for your reply… I am using AX 2012 R2, I guess the option is not available in R3 version also.
