Assigning Default value to Dateformula
How can I assign a default value to a variable with the datatype Dateformula?
If this is a table field depending on your regional setting you could set its “initialvalue” property to say 1D, or 1G for Turkish setting. If this is a only variable you could bound a control to this variable say a textbox then adjust its Dateformula property to yes. OnOpenForm assign the default value to this variable.
What abt codeunit?
You can use: <10D>
Dear Erik, I tried to assign d:=<10D>, but this is giving the compilation error - A value or an expression was expected.
EVALUATE(MyDateFormula,’<10D>’);
Thanks dear, Its working perfectly fine
