Hi
In AX 2009,i took one company data from PROD and imported to DEV. Then i synchronized database.
After that when i open AssetTable it shows all null data as junk values.
Why does it comes and how to remove them ?
Hi
What do you mean by “null data as junk values”?
If you want to be sure that you have consistent data, get the original data from backup and start again. Otherwise, either delete records in question or replace “junk values” with something else, if the problem is just with some columns.
Hi Martin,
Thanks for your reply but martin,the data i imported from PROD in that in AssetTable ,more than 20 columns are empty which i expected the same in DEV after importing,but instead of blank values those values got replaced with junk values.
