Hi friends,
Can any one please explain how to assemble an item in simple terms in nav 2013?Also where in inventory to look for them once I have assembled an Item?How would I store the assembly item to inventory.
any help would be greatly appreciated.
Open Assembly orders (search top right if its not in your menu)
New Order
Type in assembly item
Put in quantity this will put your component lines in and tell you any shortages
At the bottom select output location & bin if using bins
Click post if all stock available this will output to the place above
Pretty straight forward without knowing requirement.
thanks very much lee, it helped.
