I have created a form which will pass the table buffer as a argument to the report. The code i have written is as follows both the code on the form and the code on report init method.
The problem is that when i click the button the report opens with only 1 item where as there are more items with in this selected category why the report prints only first record can some one tell me the issue so that i can fix it.
Thanks.
FORM BUTTON CLICK METHOD:
select rboInventItemLabel where RBOInventItemLabel.CATEGORY == ‘Item Barcode’
if (rboInventItemLabel)
args.caller(element);
args.record(rboInventItemLabel);
CreateReportForLabelsMen.run(args);
REPORT INIT METHOD:
public void init()
super();
if(element.args().dataset() == tablenum(RBOInventItemLabel))
_rboInventItemLabel = element.args().record();
else
throw error("@RBO1364");
