Approved purchase requisition with project id's not converting into PO in AX 2012 R3
I created PR against project and it is approved. I’m getting error while converting the approved PR into PO by using Release approved purchase requisitions>Purchase orders.
Only PR’s created against projects throwing error all other PR’s converting into PO’s.Please help me.
I’m getting following error:
“Function CostControlPostingSourceDocumentLine::construct has been incorrectly called.”
Thanks.
It looks like a bug and i can see a hotfix for this,
KB 3109690
You should be able to search for the issues in, https://lcs.dynamics.com
Thanks Kranthi.
We raised ticket with Microsoft on this and awaiting their response.
Doesn’t the mentioned hotfix solved your issue?
Hi Kranthi,
Actually we raised ticket with Microsoft on the day I posted the issue in this forum.
They also suggested the same hot fix :).
Thank you Kranthi for your help.
Hi, i am using AX2012 R3 CU9. Is the hotfix compatible to this version? Thanks for the reply.
You are still getting the error after the CU9, then the hotfix is not a part of CU9. The hotfix might have release after the CU9, so you should be good to have it.
