Dear All,
how can i upload approve vendor list table in ax.
i am trying to uploaded but it is not working any suggestion.
Dear All,
Would you mind spending a few minutes describing what you’re trying to achieve? What’s your input data source, what you mean by “approve”, which version of AX you’re talking about, what you already tried, what “is not working” and so on.
Dear Mr. Martin,
thanks for your prompt response.
i am using AX 2012 R2 version
we have function of approve vendor in item master where we restrict user to select items if it is not approved with the vendor.
we can do this manually in item master Purchase tab Approve vendor setup.
but i want to upload this table directly from excel sheet how we can achieve this.
hope this time i am explaining clearly.
AX 2012 has the Data Import Export Framework for such tasks. Are you familiar with it?
Dear Mr. Martin.
i am familiar with this but this is not working properly as our AX is customized by our partner.
can i get some brief about this data import export framework so i will make new server standalone and will test this on AX R2 version which will be base software without any customization.
Please refer to Install the Data import/export framework. Come back here and ask if you have a specific question.
