I want to ask about purchase order workflow. I have set up the Purchase Order Workflow from the Procurement and sourcing module. I can sumbit PO , but when i logged in using another user for approve/reject PO, the yellow bar (action button) didn’t appear.
The problem is caused by security permissions. The user you want to approve PO may not have enough security permissions. Check the user security permissions and correct if necessary.
I’m a beginner user for dynamics ax 2012. I have checked the user security permission, but still can’t approve by other user . Maybe for the example, can you tell me the correct if necessary or step to make the right condition in workflow so that it can work for approve PO …
