Applying a Filter on an EDT relation
I want to create an relation between two tables using an EDT , i.e the relation node of the EDT .
lets say my tables are table A and B , so i have a grid where am using table B as the Datasource ,
i can now select the values of table on using the field whose Type is the EDT i created .
my only problem is that its loading all the rows in table A and i just want to select a few rows based on a certain criteria
any one who knows how to do this ?
Hi Angelus,
If you want to display the lookup with filter condition then override lookup method and apply your criteria.
Hari
You can use relatedfieldfixed relation type… or you can use lookup method…
http://chaituax.wordpress.com/2013/03/05/customised-look-up-methods/
Check out this for customised lookup methods.
Hi Aedula,
Thanks you solution worked.
