Apply SysLookupMultiSelectCtrl class in grid field
Hello All,
I have requirement to select multiple option from lookup control in two way. One is from dropdown that dropdown i have added on form and other is select multiple options from grid field.
I am able to achieve multiple selection option for dropdown through SysLookupMultiSelectCtrl class. However, I am not able to do same thing with grid field.
Is there workout how to select multiple options from grid field lookup.
Thanks In Advance.
Hi Jigal,
I am also facing same problem while adding multiple selection option for dropdown in Grid level…Have you find out any solution for that?
Any ideas are greatly appreciated!
Thanks.
have a look at these. Might help you!
http://yasirnedian.blogspot.in/2012/07/how-to-retrieve-multiple-selected.html
http://daxmusings.codecrib.com/2013/01/multi-select-on-form-datasource-grid.html
