Apply report filter to form
Hi Is it possible to apply the filter the user uses in a report to the form, that the report is run from! I have a report, where the user applies filters, these filters would I like to apply to the form, when the report has finished. I have tried to make a function on the form and call this function from the report. But when the report has finished the global variables in the form I have given a value in the call are empty. Am I working with 2 instances of the form or… Thanks
I presume you’re working with a tabular type form? You could try to run the form from the report, and set the tableview property. (make a variable with the datatype set to form) Anolis Sittard Netherlands
