Application version mismatch
hi,
I am working for a supporting project. i need to set the AX2009 environment as same as what my client is having. i checked the kernal version and application versions. my kernal version and client’s kernal version is same. but application version is diffarent. will it effcts to setting up the same environment. if yes, ihow can i overcome this problem. and can any one to help me what is the steps and precautions to setting up the AX environment as same as my client in my machine.
thanks in advance…
Application version is basically what you have in AX layers (.aod files). So you should install the same version of standard/third-party layers (e.g. proper SP/rollup) and then copy custom layers from customer environment. Or you can simply copy all layers from customer environment - then you’re sure that the applications are identical.
thanks for your reply martin…
can we download the rollups from the partner source?
Sure, start in Hotfixes Released for Microsoft Dynamics AX 2009.
thankyou martin…
