Hi all, I have a question concerning the (NAS). Is there a way, to start a “Shell” - Command from a Report, that runs under the NAS? I tried it with some different ways, starting a little bat file. The NAS returns no error, but the bat file was definitive not started. Best Regards feri
You can’t run reports from NAS. NAS only runs codeUnits. You should be able to run Shell, but i haven’t tried it.
Hi, if you set “ProcessingOnly” in your report to “Yes” and “UseReqForm” to “No”, then NAS is able to run reports too. Best Regards feri
Hi, Yes that’s quite right. You can execute any code from any object as long as there’s no user interface at all such as message, confirm etc. Regards
Originally posted by ara3n - 2004 Dec 09 : 19:00:22
NAS runs reports perfectly well. Of course You must set filters for You report by code, but it’s no problem to have NAS printing reports.
