Application Server Port Number
I’m trying to connect biztalk to Navision, using commerce portal/application server. At one stage in the Biztalk setup, it is asking for the IP address/port number of the application server. Now, its easy enough to give the IP address, but I dont know what the port number is, and there is no documentation to tell me. I’ve tried editing the services file to force it to a particular port number (as you would with a C/Side server), but this didnt seem to work… Can anyone help me? Thanks.
Run BizTalk Management Table - NAS port information is there
The default TCP/IP port that Navision runs on is 2407. Does that help? Failing that trawl through netstat -an Yonis
