Appending rows to a Grid whose data source is a Temporary table
Hello,
I am trying to append records to a grid whose datasource is a temporary table (E.g. when a use clicks on a button). To add a line, I would simply use the setTmpData() method on the grid table then refresh the grid; however, it replaces the grid’s contents every time, it doesn’t append it so I always have 1 record.
How can I append, not overwrite, records to a grid who’s datasource is a temporary table?
Thank you in advance!
Nevermind! The following works (although it would be nice if there was a more efficient way!):
void method()
Table origTable, newTable;
// Copy original contents
for ( origTable = Table_DS.getFirst();
origTable;
origTable = Table_DS.getNext())
newTable.clear();
newTable.BOMId = origTable.BOMId;
newTable.ItemId = origTable.ItemId;
newTable.ItemName = origTable.ItemName;
newTable.ziMessage = origTable.ziMessage;
newTable.insert();
// Append new record data
newTable.clear();
newTable.BOMId = “test2”;
newTable.ItemId = “test2”;
newTable.ItemName = “test2”;
newTable.ziMessage = “test2”;
newTable.insert();
Table.setTmpData( newTable);
Table_DS.executeQuery();
