INFOLOG://1376 >>Not enough rights to use table ‘Sum lines’ (FSHSumLines).
the user is admin and have all rights. how can I solve this issue.
is there a way to check those inflog. thanks
Is it a custamized table???
The may be due to the Configuration Keys…
Even you are an admin-if the configuration keys are not enabled the system will not allow u to access those objects…
There are no customization and all keys are enabled. do you think it is a lisence issue?
By doing what - you are getting this error…
can you put - the total error message once again???
The question required you to tell us the process steps you are undertaking in the system, copying and pasting the original issue as a response does not really help anyone.
Ok,
I tried to access the PO details and I get this message. Also note that all keys are full control. and the user is the admin. So I was wondering why and how to solve this issue?
there is no object - FSHSumLines
Check whether there are any customizations???
‘FSH’ prefix indicates presence of an Ax add-on. Unfortunately I don’t remember name of this add-on.
Thanks Harish
It would be helpful if your are able to recollect and tell us about the Add-on…
There is no customization. This is a fresh AX 2009 for retail and Imported a demo DB on it.
In that case, cube is trying to consume a non existent table in your environment. You should be able to clean your cubes by following guidelines published here - http://blogs.msdn.com/b/emeadaxsupport/archive/2009/04/29/default-cube-advisor-tool-for-microsoft-dynamics-ax-2009-has-been-released.aspx
It is an add-on not a customisation - is it a Retail add-on? Is the demo data a retail based demo?
It is definitely an add-on. The way to go forward would be to follow steps in the link I provided earlier. This will help in cleaning cubes and get it working
