AP Check Print
Can anyone tell me where to get Stub-Check-Stub print for object 1401 AP Check print thanks
Good question. I recently had to customize a check to have a check - stub - stub format, but I don’t think any standard Navision report will do the job. I think you will have to customize it, or buy it from a partner.
David is correct. There is not a base Navision version. Any North American NSC should have these documents as they are pretty much needed for all clients. Ask your NSC…They should be able to give it to you or (more likely) provide it to you at a reduced rate.
For Navision version?
John, Chris is right, probably your NSC is already having it (at least we’ve had to create that report for most of our customers in all the different versions… so probably others were having to do it to :). Just ask your NSC. :slight_smile:
