Hi Is it possible to run AOS on multiple IP addresses? Where does Axapta write the information on which IP the server is running? It is required as my clients (remote and local both) have different ranges of IPs. And I am unable to connect Clients having IPs not in the same range of IP of Server. Thanks for your reply in advance.
