AOS Printer Properties
We have configured a canon printer as an AOS and are using AX2009.
We are needing to have the ability to make changes to the printer properties, specifically to staple.
The printer drivers are loaded locally on Win 2008 R2 x64 server and the default was set up to staple.
While looking at the printer in the print management area in AX, the Properties button is not activated when set up as AOS.
