Aos instance
Hai
I have 2 instance in a server.One is port number:2712 and other is Port number:2713.
I want to delete entirely one instance(that is 2713).How to do this.
HI Ravikishore,
Open – Client configuration utility – in Connection tab — there you can find the istances…there you have the option to delete the instance…
Naresh Kolli
HI Ravikishore,
Open – Client configuration utility – in Connection tab — there you can find the instances…there you have the option to delete the instance…
Naresh Kolli
Hi naresh
Thanks a lot for your help.
AOS in Microsoft Dynamics 2009 is getting crashed when submitting the workflow>What could be the reason??
Govind
