plz tel.
in my system ,when i open AX2009
it shows error,“aos could not open,connection should estblish”
if start the service it opend bt when i restart the system,when i opend nxt time it shows same error .plz tel me hw to solve this
plz tel.
Is the aos on the same machine then check the service again and if on another server then client config file of Axapta Client may be having wrong details.
ok sir, but in services —>Dynamics ax>status mode is is Automatic, but it doesn’t work.thats y i can not open AX directly.
Error is " Application could not be opened AOS Could not be connect with server"
This error shows only when the aos services are stop. U can also check the SQL services.
