Anonymous authentication to AIF HTTP service
I have created HTTP inbound service in ax 2012 and published. Now i am trying to consume that service from visual studio which is installed on my own machine. While adding reference i am getting one popup and asking credentials, i entered the login details and clicked ok button even that pop up is coming again and not able to consume that service. But in browser once i enter the logins service information showing. Please help me.
Thanks in advance.
Thanks &Regards
Anilkumar
Hello Anilkumar,
Hope you found the solution, if not I recommend you to contact technical support team I guess the will assist you with your problem. In case, you still need help write to me) I hope somebody from my company [plug removed by moderator] will get back with the answer.
I did not fund solution, can you please hellp. Thanks for the reply.
Thanks &Regards
Anilkumar
