Hello
I would like to show only the lines where the total amount is not equal to zero but i can’t apply filter with success.
Has anybody got a solution ?
Thanks in advance for your help
SG
Hello
SG
Its not possible in NAV, but still there is a solution…
Export your Analysis View to Excel - that will create an Excel Pivot Table. There you will have enormous possibilities to “slice & dice” your data - far more than in NAV, just to mention several levels of grouping by row/col, adding new calculated fields, filtering rows/cols etc. Most important - in NAV form you can`t see entries with BLANK dimension value.
such filtering is possible in Exclel 2007 Pivot table only - earlier versions doesn`t allow that. In 2007 there are added options like “Fitler by Value” and “Filter by name”.
Generally, I dont like Office
07 because of its Barby house like interface, but MS has added much new analytical & graphics functionality to Excel
07, so I forced myself to use it [:^)]
