An error occurred when importing the database file in the test environment to the local environment:*** An unexpected failure occurred: Data plan execution failed with message Unable to reconnect to database: Execution Timeout Expired. The timeout period elapsed prior to completion of the operation or the server is not responding…
Does anyone know why this is
Were you able to find any additional information in the event viewer on the test environment’s server?
I don’t quite understand. I want to import the database of the test environment into the local environment. Why should I look for other information in the event viewer on the test environment server?
Sorry. I meant on the local server. Is there anymore information about the error message?
Sorry, I couldn’t find more information
