Hi Navisionerz
When printing a RDLC report in NAV 2013 R1, i get the following error in the preview section:
An Error occurred during client rendering “Parameter is not valid”
Any ideas please, thanks.
Hi Navisionerz
Sorted this, it was do with image on the report, it was calling the image from a BLOB field wihtin a record, this BLOB field must have had bad data, delete data within BLOB, reload back into BLOB field. Easy in my case as it was the stanadard piocture field within the Item Record. Sorted.
Thank you for sharing the solution
