Amount in word very urgent
Hello,
I Can change the amount into Spell but the problem
Present Situation
=amount (58.200) = Fifty Dollar and Twenty files only.
My Request
=amount (58.200) = Fifty Rupees and two hundred files only.
where i can change in ax ?
Hi Reddy,
I don’t know about amount function that you mentioned. Please refer this link http://ax2012madhav.blogspot.in/2012/12/numbers-to-words-in-ax-2009.html
Hari
Thank U given the link .
But that code is not working for my requirement.
You can use code from method Global - > numeralsToTxt
Yes i tried.
Present Situation
My Request
This is to convert number in india numeric format please check it out
public static TempStr INDNumeralsToTxt_IN(real _num)
int numOfPennies = (decRound(frac(_num), 2) * 100) mod 100;
real test = _num - frac(_num);
int64 numOfTenths;
str 20 ones[19], tenths[9], hundreds, thousands, Crore, Arab, Kharab,Lac;
int64 temp;
str 200 returntxt;
int64 testLoc;
real modOperator(real a1, real a2)
int tmpi;
real tmp1, tmp2;
tmp1 = a1 / a2;
tmpi = real2int(tmp1);
tmp2 = tmpi;
return (tmp1 - tmp2)*a2;
real checkPower(real _test, int64 _power)
int64 numOfPower;
if (_test >= _power)
testLoc = real2double(_test);
numOfPower = testLoc div _power;
if (numOfPower >= 100)
temp = numOfPower div 100;
returntxt = returntxt + ’ ’ + ones[temp] + ’ ’ + hundreds;
numOfPower = numOfPower mod 100;
if (numOfPower >= 20)
temp = numOfPower div 10;
returntxt = returntxt + ’ ’ + tenths[temp];
numOfPower = numOfPower mod 10;
if (numOfPower >= 1)
returntxt = returntxt + ’ ’ + ones[numOfPower];
switch(_power)
case 100000000000 :
returntxt = returntxt + ’ ’ + Kharab;
_test = modOperator(_test, 100000000000.00);
break;
case 1000000000 :
returntxt = returntxt + ’ ’ + Arab;
_test = modOperator(_test, 1000000000);
break;
case 10000000:
returntxt = returntxt + ’ ’ + Crore;
_test = modOperator(_test, 10000000);
break;
case 100000 :
returntxt = returntxt + ’ ’ + Lac;
_test = modOperator(_test, 100000);
break;
case 1000 :
returntxt = returntxt + ’ ’ + thousands;
_test = modOperator(_test, 1000);
break;
case 100 :
returntxt = returntxt + ’ ’ + hundreds;
_test = modOperator(_test, 100);
break;
return _test;
ones[1] = “@SYS26620”;
ones[2] = “@SYS26621”;
ones[3] = “@SYS26622”;
ones[4] = “@SYS26626”;
ones[5] = “@SYS26627”;
ones[6] = “@SYS26628”;
ones[7] = “@SYS26629”;
ones[8] = “@SYS26630”;
ones[9] = “@SYS26631”;
ones[10] = “@SYS26632”;
ones[11] = “@SYS26633”;
ones[12] = “@SYS26634”;
ones[13] = “@SYS26635”;
ones[14] = “@SYS26636”;
ones[15] = “@SYS26637”;
ones[16] = “@SYS26638”;
ones[17] = “@SYS26639”;
ones[18] = “@SYS26640”;
ones[19] = “@SYS26641”;
tenths[1] = ‘Not used’;
tenths[2] = “@SYS26643”;
tenths[3] = “@SYS26644”;
tenths[4] = “@SYS26645”;
tenths[5] = “@SYS26646”;
tenths[6] = “@SYS26647”;
tenths[7] = “@SYS26648”;
tenths[8] = “@SYS26649”;
tenths[9] = “@SYS26650”;
hundreds = “@SYS26651”;
thousands = “@SYS26652”;
Lac = “@ZON470”;
Crore = “@ZON471”;
Arab = “@ZON472”;
Kharab = “@ZON473”;
test = checkPower(test, 100000000000);
test = checkPower(test, 1000000000);
test = checkPower(test, 10000000);
test = checkPower(test, 100000);
test = checkPower(test, 1000);
test = checkPower(test, 100);
if (test >= 20)
testLoc = real2double(test);
numOfTenths = testLoc div 10;
returntxt = returntxt + ’ ’ + tenths[numofTenths];
numOfTenths = numOfTenths mod 10;
test = real2int(test) mod 10;
if (test >= 1)
numOfTenths = real2int(test);
returntxt = returntxt + ’ ’ + ones[numOfTenths];
if(numOfPennies)
returntxt = returntxt + ’ ’ + “@SYS5534”;
if (numOfPennies >= 20)
testLoc = real2double(numOfPennies);
numOfPennies = real2int(numOfPennies) mod 10;
if (numOfPennies >= 1)
numOfTenths = real2int(numOfPennies);
returntxt = returntxt + ’ ’ + ones[numOfTenths] ;
returnTxt = returntxt + ’ ’ + ‘paise’ + ’ ’ +‘Only’;
else
returntxt = returntxt + ’ ’ + ‘Only’;
return returntxt;
For your code output is :
amount : (5000.200) in word
Fifty thousand and Twenty rupee only.
But i need amount : 5000.200 in words
Fifty thousand and two hundred only.
