Does anybody have an idea how to make a function that returns an amount as text. That is 1.234,00 => onethousandtwohundredthirtyfour?
You can fill a table with the text which stands for the number. A get can give you the result. Solution: When you fill this table, remember, that every spoken word for an number > 100 is number < 99 + 100 Example: onehundred - twenty
Hi Have a look at Report 1401 Check/Cheque This has a similar type of function that you are looking for.
hi You can follow what Stephen Gault have mentioned. I have developed my own function to do the same. WR hari
Hi, See Report Id 1401 named as CHECK and reffer the code for Ammount to text bye
