Amend inventtrans Issuance cost
In Inventtrans, Ax has Receive and Issue Qty. AX allow to amend the Receive cost via Inventory closing> Adjustment function. Is there any way to adjust the transaction for Issue cost?
Thanks.
regards,
Kong Yu.
The issue cost is the calculated one, which depends upon the costing methodology(considers the wt avg in all cases except Standard costing), Changing the receipt cost obviously will have an impact on the issue cost(after a recalculation or closing depending upon the costing method).
Issue cost is adjusted an the time of inventory recalculation and closing. I don’t think issue cost can be adjusted manually.
Pranav…
