look at the image below…always pinging when i open tables or forms…still i can work with dynamics AX…but i need to know what causing the problem…and how to get rid of it…thanks in advance…
I would recomend you to check your database and the communications
I will start from basics i.e. start checking the Application folder settings based on AX Installation guide.
Also it appears to me that you get this error only for USR layer. Compare this to the other layers and see what is different.
