Allow edit to be enable in a form method
Dear all,
In the payment journal, there is a field called payment status which is disabled completely. It has to be enabled when we select a field for the payment mode. Like If the payment mode = “check” then the payment status field has to be enabled.Orelse it has to b disabled always. For this I made initially Payment status Allow edit in the form level made to be no. Then wrote a method on modified of the payment mode field.Everything was written in form level. It’s not table form level which is as below.
Forms\LedgerjournalTransVendPaym\LedgerjournalTrans_PayMode1:modified
public boolean modified()
boolean ret;
ret = super();
If(ledgerJournalTrans.PaymMode == “Check”)
ledgerJournalTrans_ds.object(fieldnum(LedgerJournalTrans, PaymentStatus)).allowEdit(true);
return ret;
When I excute it, initially the field is disabled. But on selection of payment mode the field is not enabled. Please let me know whether the above method having some error.
Thanks…
