Allocation vs account distribution in AX 2012
I was wondering if the allocations and account distributions can meet the same requirement in AX 2012. A little bit confused when to use allocation, and when to use account distribution in AX 2012.
Thanks in advance,
Accountting distribution and allocation are completely different stuffs. Accounting distribution basically gives you a snapshot of how the ledgers entries will be created after posting document whereas for allocation, you create allocation rule and you set a parameter where a certain percent or amount of the concerned ledgers will be posted to other ledger as per setup.
Pranav…
This post may help about the allocation .
http://dynamicsuser.net/forums/t/34863.aspx
Can you tell me how to create accounting distribution through code?
