we have variable allocation process in ax 2009, and it has some methods, pls give some example
for better understand , if possible.
You are expecting the explanattion for allocation methods like “Basis”, fixed weight etc…or is it something else you are asking for…? please elaborate
Hi Santosh,
yes Im expecting the explanation with example ,
I went through the manual but I couldn’t get it.
If you know more abt variable allocation, pls let us know.
Hi
By allocation Terms you automatically allocate amount to different accounts and dimension,
there are 2 way for allocation, one is you define in chart of account for a account you want allocation,
E. G. you have say an electricity expense account and every month you want to allocate electricity expense to different Cost Center then you can define that rule in Allocation term. At the time of posting system will automatically allocate the amount to different accounts or dimensions. this only works with
The other is generated allocation- Where amount is already posted into one account and you run allocation rule from periodic and allocate the amount based on the rule defined.
Regards
Rajesh Kumar Sharma
Thanks Raj kumar ,
Awesome explanation about the difference between allotacion funcitonality.
Can you explain which option is suggestable in a practical business scenerio ?
Please share your experience.
