I have created columns dynamically and totally there are 8 columns. My issue is that the columns are not displayed in the single row, and also overlap with one another,
How can I adjust all the columns in a single row like it happens when we add controls in the design normally.
follow the same in Box Control also(for outer line like Table Structure)…
If u set Top = 2.50mm in all controls(8 columns), All the fields comes in single row(one line) from top of the page 2.50mm
Left is for align the fields one after one in single row
Yea that will work fine… but the problem is if suppose i have to add few more column and suppose i cant adjust the space from then on, what can i do after that… cause the number of columns to be displayed is based on the user.
