Greetings,
I created changed based alert rule. And I am receiving emails of it.
Can I get Link for the source in email as we get in AX popups.
I tried Dynamics://%LinkToBusinessData% under Email Template But I am receiving just text as "
Dynamics://1?DrillDown_149".
Can anyone help me in this.
Regards
Hello
please refer below example
may be you are missing href
technet.microsoft.com/…/aa834376.aspx
also
To use the drill-down functionality from an e-mail message, users must work from a local Microsoft Dynamics AX client with a local version of the Microsoft Dynamics AX configuration file. The drill-down functionality does not work if users access Microsoft Dynamics AX by an application server
I tried with href also. I managed to get HTML code which shows the link. But when I click on that…its not taking me to the source of the alert.
By the way, I am connecting thru AX client only.
regards
are you using AX 2012 R3 CU10?
also check your application and kernel versions are same
is “Dynamics://%LinkToAlert%” working?
