I pretend alert My user, if he creates a new line in purchase line with the same Item No. that was already inserted in tthe same purchase line? how can I do That?
I Tryed this on Table Purchase Line on No. Validate
IF (“No.” = PurchLine2.“No.”) THEN
MESSAGE(‘There is already one item with the same no. inserted, try another one’);
You need to filter on PurchLine2 with Document type,document no and type and no then if you find the line then show the message…
hope its clear…
Where do I have to Put this mesage
On Tale Insert Triger or in No. - OnValidate()
PurchLine2.SETCURRENTKEY(“Document Type”,“Document No.”,“Line No.”);
PurchLine2.SETFILTER(“Document No.”,“Document No.”);
PurchLine2.SETFILTER(“No.”,“No.”);
MESSAGE(Hello);
Put it in No. Onvalidate
PurchLine2.SETRANGE(“Document Type”,“Document Type”);
PurchLine2.SETRANGE(“Document No.”,“Document No.”);
PurchLine2.SETRANGE(“Type”,“Type”);
PurchLine2.SETRANGE(“No.”,“No.”);
IF Not PurchLine2.ISEMPTY THEN
MESSAGE(Hello);
HI There,
You may change your code in No.-OnValidate trigger as follows:
IF PurchLine2.COUNT >= 1 THEN
MESSAGE(‘Hello’);
